As you might know it is possible to use an Essence (2nd gen) - or a Core - as an integrated part of a NL-BeoVision - to let it share the speakers of the tv.
Would be nice to hear from someone, who uses this kind of setup on a daily basis.
How does the setup behave, when you start an Essence source via the app?
Does all sources act the same?
Does using Spotify Connect turn on the BV?
How about when you cast using ChromeCast to the Essence - or Airplay to it.
Or using bluetooth?
I suppose, that these sources also are visible in the source list (of e.g. a BV11) - (this is not the case, if the Essence is just connected to the tv).
Does the timer functions of the Essence turn on the tv, then?
When the Essence is integrated with a BV, can it still be connected to another (in another room)?
All these questions because I ‘only’ have personal experience with the Essence as a connected (to a BV in another room in my house) device.
A post from Mr Andersen in another thread about the behaviour of the Bang & Olufsen app used with an Essence/Core that is integrated with a BV triggered my curiousity.
Read here:
