BS 3 Version
Can anyone advise how you can tell what version of BS 3 you are running.?
Thank you.
Do you mean "type number"? In that case 2720.
Andreas,
I was meaning the version number. It was my understanding that there were changes to BV3 since it's introduction, just wondering if there was anyway to tell what version I have.
regards
Keith
If the device has changed then wouldn't the type number change as well?
I'm an automotive audio and acoustic engineer. I design loudspeakers and full sound systems for new automobiles. I also dabble with studio, consumer and pro audio projects from time to time.
As others have stated there are different type numbers which relate to different countries normally.
In the case of the Beosystem 3 there has been two versions:-
  • The Mark 1 has type numbers 9600 to 9612 inclusive
  • The Mark 2 version released in October 2008 has type numbers 9615 to 9628 inclusive
The latest TV software version is 7.05
Thank you Keith
