I try to add a second BL2 to my existing BeoSystem 3 7.1 setup to make it a full 7.2. The first BL2 is connected to the Subwoofer socket and the second daisy chained from the first one. Both Beolabs power on - light goes green. The problem is that the sound is very weak from the second BL. With full power the main element of the first bl moves almost an inch and same element in the second one very little. Both speakers are ok - that has been tested.
The second Beolab 2 line is gray in the menu Sound Setup/Speaker types and can not be modified. Roles are assigned as Subwoofer and Subwoofer. Sw version is 5.02.
Any advice?
