Sorry to come in as "tail end Charlie"on this topic,but if the disc motor can be heard running fast before rejecting play,it may be a power supply problem rather than servo.An easy fix if you can do "fiddly" soldering ?
Always a good investment to replace the caps on the servo board,particularly if they are the little blue jobs.The black type seem to last quite well.
There were two types of cd transport used on the '9500.The earlier one used a "bombproof" induction type motor,and the later one was direct dc drive.The later mech seems to have been more troublesome.The various mech's and servo boards are not interchangeable.
Just my "two pennuth".
Regards,
Nick
This is a new possibility! I'll add it to my list of things to investigate. I'm not at all technical and wouldn't attempt to fix the unit myself, so I'll need to find a repairer (NOT the B&O centre) to look into the caps, power supply etc. At least I now know that the unit can be repaired without replacing the whole innards. As I mentioned previously, I'm now away until mid January, and won't be getting the Beocenter back from Exeter until then. If anybody can recommend a repairer, in the South West or London areas, I'd be grateful
Tony
