Broken CD player on Beocenter 9500
Orava wrote:
I just repaired, Beocenter 9000 CD. Changing caps did not help, so I found used CDM4/19 transport, and put it's laser unit to 9000's CDM2/10. And it works beautifully.
Of course must check adjustments to make it perfect.
ps. these transports are found for ex. older Philips players.
I'm on a steep learning curve here, I'll need to get my 9500 back from the B&O workshop (which won't happen till after Christmas now as I'm about to go away for a few weeks), and have a good look at it, you guys have given me several options now - clean the head - replace the capacitors - replace the CD transport.  I'll start with the easy option!
joeyboygolf wrote:
Jandyt wrote:
tournedos wrote:
kokomo wrote:
link
😂😂 Love it!
Priceless!! And it's plus VAT!
Yes. And it is not a fake, but a genuine printout from the online spare parts ordering system, pricing for installations that are not an accredited Sony service. I have no first hand part with this event, but apparently Sony in Finland didn't quite like it being published, hence the censored fields...
Be aware though that the BC9000 uses a completely different CD unit to your 9500 so don't go looking to use the same unit as mentioned by Orava. I'm still pretty sure that it is a capacitor problem though as the CD unit in the 9500 is pretty robust.
Chris.
PS Mika - love that screw.....😂
Hi Cris
Just curious, what mechanism is used in 9500?
I have heard that CDM2 and CDM4 laser units were interchangeable but I have never had the need to do it as of the 30 or so units that have needed CD repair from me, it has always been the C2103 capacitor that has been the culprit.
I believe that several European members as well as Auric in the US have reported success with swopping laser units from Philips branded CD players or indeed have purchased new laser units from Philips spares suppliers.
I think that the point that Chris was making is that it is not possible to lift the complete CD mechanism from a BC9500 and plant it in a BC9000 and certainly not cost effective even if it were possible.
Yes, not planning Anything like that, just curious...
I have cd5500 wiht same fault as AJStokoes BC9500. I have changed cap to this also, didn't help. Unit has been lying on the self now for some time, because I don't have working scope. This uses also same radialswing laser unit.
You must be exceedingly unlucky to have 2 CD units with blown lasers! I have always found that it is the capacitor has been at fault.
Are you familiar with the school of thought that says that only the original make and type of 33 microfarad capacitor will work 100% in this application.
There are numerous post on this subject in the Workbench area of the forum.
I had a blown laser in my BC8000 as well. The trouble in that case was that somebody had been there already before me, replacing some other caps (and forgetting to solder a couple of them!!!) and doing god knows what...
Yees, but, cause I haven't found those blue1's, I tried several different types, no go. I don't belive it's laser issue here, something else.
Sorry to come in as "tail end Charlie"on this topic,but if the disc motor can be heard running fast before rejecting play,it may be a power supply problem rather than servo.An easy fix if you can do "fiddly" soldering ?
Always a good investment to replace the caps on the servo board,particularly if they are the little blue jobs.The black type seem to last quite well.
There were two types of cd transport used on the '9500.The earlier one used a "bombproof" induction type motor,and the later one was direct dc drive.The later mech seems to have been more troublesome.The various mech's and servo boards are not interchangeable.
Just my "two pennuth".
Regards,
Nick
