Normal 0 false false false EN-GB X-NONE X-NONE
Hi All,
Few weeks ago I bought BeoSound 9000. I bought it as faulty (does not power up) and my intention is to make it fully operational (so good intentions I guess). It is such a beautiful piece of electronic that scrapping it would be just a shame.
This particular CD player apparently went thru number of people who tried to fix it but they didn’t succeed. I guess I’m next one in the line here. Just to be clear I’m an electronic engineer by profession and I hope this helps here.
Version of BeouSound 9000 I bought is:
Mark II
Type no: 2563
Inside there a firmware version: A2 SW 2.0 8343406
It is 110V version that someone swapped mains transformed to the 230V version.
I manage to find schematic for Mark III version and this is what I’m using for my debug. So far majority of components and connections matches this schematic. I found some differences in interconnectivity around main processor only.
I went thru Mark III schematic and after some time I discover that main relay does not engage (hence player would not start). I short transistor (TR17) that enables main relay (RL1) and this brought some live to the player. Here is what I manage to observe:
- Using main keyboard I can:
o Enable and control radio (fully working including RDS, I can hear audio thru headphones)
o Enable and control clock (looks like fully working),
o Control all sound parameters (balance, volume, bass, treble, loudness). I got access to all of those controls after shorting pin 4 and pin 2 on speaker Powerlink connector.
o When in CD player mode, player behaves randomly. If particular sequence of events is followed I was even able to play CD. It is not robust thou. Sledge does not move as expected. When hitting end it still tries to pull sledge (end sensor works and I can see REFERNCE POSITION signal from END STOP DETECTOR reaching P55 on PCB35 (Motor Control). It is like motor processor ignores the signal?
- I have Beo4 that I attempted to use to control CD player but without success. I did follow suggestions on this forum: /forum/general-discussion-and-questions/bs9000-ir-remote-problems;PageIndex=1 but CD player does not respond to commands from remote.
o I did get to the P14 connector on PCB34 where I measure pin 3. I could see that IR receiver picks up signal from remote but for some reason microprocessor ignores it. Since I can get access to Volume controls in the player (balance, volume, bass, treble, loudness) and pins 2 and 4 on Powerlink are shorted I assume player should respond to remote controller.
So I’m starting to hit the wall and would much appreciate help and suggestions from more experience people.
One of my questions would be, what firmware in BeoSound checks (after power up) before it enables relay RL1 using transistor TR17 that is controlled by IC7 (on Power Supply PCB4 board)?
Maybe clue that would answer why CD player does not won’t to start is there? Maybe main microprocessor performs some sort of check-up sequence and since something does not work it stops? If I remove short that enables RL1 I can only get main red LED blinking slowly (CD player does not respond to any button at all).
Another question would be regarding any suggestions how I could debug it further.
Is there a chance that there is some issue with firmware code itself?
Am I facing here, buying new PCB35 (Motor Control) or PCB34 (Power Supply)?
Thanks for your time and appreciate any help.
Cheers,
Henryk
