BR1 without BT:
Product list: "BEO4 AV". Remove all other.
Hide all sources except TV and DVD.
Press TV button and you will see… DTV and… TV, DVD
You can't to remove DTV!!!!
You can't move DTV's position on the list. Because with "Setting" "Move" you see only TV and DVD !!!
Worst each time you are pressing on TV button, remote send DTV. Because DTV is at the top.
Reseting remote don't change this behavior…
Bug or user mistake ?
thanks
