Hi, I've got a beovision 8-40 and a friend is offering me a pair of bose cinemate speakers (
Bose speakers with beovision 8-40
Nope, they are not compatible. You probably can use them by adding a Beolink Passive in between the BV8 and the speakers. Please note that you then only will be able to have stereo output. I.e no surround capabilities.
/Claes
As far as I can see from the Bose manual there is an amplifier along with these speakers. Therefore it should be possible to connect this system to one of the powerlink sockets on the BV8-40 with a powerlink to composite adapter.
The manual for the Bose speakers says:
" If your TV provides both fixed (FIX) and variable (VAR)
audio output connectors, use the fixed connectors for
higher sound quality. Be sure to select Fixed in the
setup menu of your TV."
If "fixed" mean line level, then it may work.
Too bad the BV8 has no digital out, because that is an option that Bose speakers has.
