hi all
I have a pair of Beolab 400 speakers and would like to connect them to my Beocentre 9000 - what do I need to do that? I have power link cables but they do not fit the Beocentre 9000 - any ideas?
hi all
are you sure you have the right ones? could you post a picture so we can see if you do or don't? thanks
I know I don't have the correct connections on the Beocentre 9000 - it only has connections for passive speakers. The Beocentre 9500 has the powerlink connections. I was operating off a manual online which was for the 9500 at the time I researched the correct connections.
thanks worked a treat - had some old RCAs I found which work well.
