Bluetooth adaptor direct connect to powerlink cables mk3?
Hi
I want to find the most simple way to replace a Beosound 2300 with a bluetooth adaptor. What can I choose?
I want to find a active version of the Hall Audio 2x8 to passive speakers. So simple as that. And I don't want to change the cables, so therefore I want to use the exiting powerlink mk3 din cables.
There must be a more simple way than a Beosound Essence, there must be a Hall Audio 2x8 "active speakers version".
Connection hub
Personally I would go for something with airplay or Chromecast. Bluetooth should be used for headphones only.
Chromecast - but then I cannot use the powerlink cables?
No.
But you can put one Chromecast directly next or under the speaker. Use one Chromecast for each speaker and group them together. Tada, wireless Pentas 😁
So i put them direct into the line in? Two chromecasts? And how do I then play them together?
You'll need a Beolab 2 adaptor with a PL-Y splitter. The BL2 adaptor will allow you to turn the PL cable into RCA as well as trigger the speakers on. From there just connect your source to the cable and away you go. I'm sure Steve from Sounds Heavenly can provide you with it.
You group them together in the Google home app.
Then they will show up as a single device/group in your music app. Like this.
You are even able to adjust treble and bass from the google app. Each speaker separately 🙂
Ah, you know... A little B&O here, a little there
What question are you answering here?
Sorry BeoMegaMan, I see now you answered how he can keep the powerlink cables.
As the Pentas has line in, there is no need for them.
