Hi again,
After further perseverance the firmware finished its installation at 150%. But everything went really smoothly once it downloaded everything. All configuration settings were carried across into the new firmware was previously I've had the network IP address reset and macros which would not trigger so far very happy.
The new BeoLink2 app is starting to grow on me, I like the interface and had a little bit of a clean up of the programming to make things look cleaner on the interface but there does seem to be some problems controlling PUC sources (maybe still work in progress) so far I have noted the following items:
1. When using Virgin Tivo the stop button does pause live TV but the Play button changes source, pressing stop again resumes live TV
2. I have Plex Media Player on a Mac Mini and have lost the ability to navigate around the interface because the Colours and Arrows screen is not displayed (or I couldn't find it)
3. Like reported earlier, I use custom strings to drive Rako lighting and Somfy blinds using buttons under Scenes. It would be a great enhancement to specify where these buttons could go, i.e. Lights and Shades.
Also noticed that there is the ability to define strings, I haven't played with that be excited that it may be able to display the status of items in the Beolink2 application. Something to try at the weekend.
Steven
