Hi all
Is it possible to dimm a KNX Actor through the BLGW and Beolink app by just sliding a slide? And, will the level in the app be adjusted if it's changed on the KNX side?
I'm wondering if I should upgrade my MLGW to a BLGW in regards to my KNX installation, but unfortunately I hardly can find any information about the interaction with KNX.
Thank you so much for any hints or comments
Regards
Reto
