Hi everyone
I searched the forum for an answer to my problem but I didn't find anything and so I decided to open a new thread.
I have the following ml / nl configuration (see photo below):
Login to view image
The NL / ML BLC is set up like this:
while BeoPlay A6 is set up like this:
The system works well, the audio sources are reproduced by the devices correctly.
The problem turn up when listening to an ML source (example: radio from Beosound 5) on BeoPlay A6 and I want to change it to another ML source (example: A-mem from BS 5). The change of source triggers the BeoLink Passive to turn on and so that the sound is also reproduced in the kitchen. This does not happen if I switch from an ml source to an nl source and then to an ml, (example: radio from BS 5 -> TuneIn from BeoPlay A6 -> A-mem from BS 5) in that case the sound is reproduced only on BeoPlay A6.
The problem is not affected by how I change the sources (I tried both with the Bang & Olufsen App and with the beoremote one BT).
I'm looking for a way to remedy this defect.
Any advice is welcome
