BL8000 + BL2 how to setup with essence
Hiya follks,
Been searching the forum and Google vigorously and cannot seem to figure out how to set up BL8000s AND a BL2 through an essence to work wirelessly and if I should get the Core and do it because it's still getting the updates and still being produced unlike the Essence MK2.
I figured a Y splitter for the speakers and then a convertor for BL2 but if I went for the Core how would I do this considering there is only one PL slot in the Core as far as I can see from the specs on B&o website..
Please advise! :)
Hi IndyBoy1007,
I think you need to use one cable between the Essence and the BL2 (Powerlink RJ45 to Powerlink 8-pin DIN) then one cable each between the BL2 and BL8000s (Powerlink 8-pin DIN to Powerlink 8-pin DIN).
I don’t think you can connect them wirelessly without other hardware.
Lawrence
Hi IndyBoy1007,
Welcome to Beoworld!  Yes, Lawrence is correct, you just need one Powerlink to RJ45 cable from the Essence or the Core to the Beolab 2 (
Hello hello! :) So grateful for the input from you both,
My hope is to be able to play my music from my phone spotify etc through the 8000s and use BL 2 to override bass from the 8000s.
Overriding the base and true stereo are much less important to me at this stage than being able to play to the speakers and subwooferf from my phone which is the main objective - is this the setup you're describing and is this the only way without other hardware?
My (novice) understanding was the core could make the 8000s wireless in fact it says so as an example on the website advert - apologies if I'm being dense here still very new and keen to learn
Please do advise!
Ahh I think I've been unclear - when i said wirelessly I meant to be able to play from my phone to the speakers I didn't mean to imply wireless as in I dont want cables running - hope that helps
Totally my mistake
*facepalm*
Are you talking wireless from your phone to the essence/core, or wireless from the essence/core to the speakers?
Yes the Core will allow you to stream music wirelessly from your phone to the Core without any extra hardware needed.  It will also stream wirelessly to newer speakers (eg. Beolab 18, 20, etc) with WiSA receivers built in, without anything extra needed.
To get a wireless link from the Core (and hence from your phone) to older speakers like Beolab 2 and 8000, you need B&O's Receiver 1 boxes (one for each mono speaker like Beolab 8000 and two for each stereo speaker like Beolab 2).
Hope this helps.
Kind regards, Steve.
Don’t forget the option of using 3 chromecast audios and grouping them together.
I think Core does not have WISA bulit in. That was a reason for me to go for the Moment...
Sorry, thanks for the correction!
