Well, four BL5s sound quite disorienting on most kinds of music, to be honest. I've heard it several times. And it's a really overkill way of achieving SPEAKER 4 or 5 sound in a room.
I've also heard the BV9 with two BL5 fronts and two BL6000 rears, demonstrated by the person who headed the work on the BV9, who said the 6000s did the job as rear speakers excellently.
I wasn't going to involve myself in this thread, as this topic has been covered often here at BeoWorld, but there is little need for matching speakers all around unless you are listening to the 0,001% of the world's music that is created for matching speakers all around. Movies don't require it either. Good SACD recordings use the back channels to provide the hall/music stage ambience and true rear reflections, not to deliver critical musical information, and therefore do not require matching all around speakers. The new HD Audio formats may make enhanced use of the opportunities for storing higher resolution information for the other sound channels - but that involves extra work during production, and movie theaters aren't geared to process this -- which means you would be creating such mixes for advanced home theatres.
If you like to upmix two-channel to four or five channel, then as a personal preference you can go with identical speakers all around. But if you want precision sound placement in your media room, that's probably not a good solution. Everything will sound harder to place and larger than natural.
However - there is work going on at several brands with connecting the subwoofer info to the mid range "traveling sound" perspective. Usually, the subwoofer/woofer sound impulses can't/shouldn't be placed in space -- the bursts should just be there in the room. Anyone with BL5s will testify to the advantage of being able to deliver bass supporting a source either to the left or the right in a soundstage.
It's possible to move the bass if you have identical bass units in the four corners of the room. You then follow a traveling sound in the mid-range, and tie the bass perspective to this traveling sound, fading woofers up and down with Digital Signal Processing. You then get a bass experience that appears to accompany the other sound, lending weight to it.
Should that becomes a standard feature, you might want to look into at least placing subwoofers in the back corners. You will also need to have your own house as any apartment neighbours would be turning up to spit roast you!
