Hi, I've got a new addition: a Beolab 3500 MK 2 with SW 3.1XX
Problem: the OPTION (s) cannot be set. The combination LINK + (optinonnumber) + STORE does not work. On my operating LCS900 SW 1.0. this combination works well.
On the new MK2 definitely the IR module is not defective, because commands such as MENU MENU 04 GO are accepted and also acknowledged on the display.
Do you have a solution?
Best regards and thanks in advance!
MichaBL3500 MK2 - OPTION Setting is not possible
Setting the option is different between BL1000 and Beo4, see below.
Both the BL3500 and main system have to be in standby when setting the option
Preprogramming the BeoLab 3500
The BeoLab 3500 can be preprogrammed for the following
setups (options):
Option 0. To be used if you want to disable remote control
operation of the BeoLab 3500 (to re-enable remote
control, select one of the other options).
Option 4. To be used if you install the BeoLab 3500 in
the same room as your central system (e.g. in a large
L-shaped living room with two separate listening
positions).
Option 5. To be used if you install a TV set in the same
room as you BeoLab 3500.
Option 6. To be used for a setup with the central system
in one room and the BeoLab 3500 in another, as described
in this guide (this is the factory setting).
Using a Beolink 1000:
– Press LINK, the appropriate
number (0, 4, 5 or 6), and
then STORE.
Using a Beo 4:
– Hold the • button while
pressing LIST.
When the Beo 4 display reads
OPTION?, press GO.
– Press LIST twice to display
L.OPT and then key in the
appropriate number (0, 4, 5
or 6).
The preprogramming is done with a Bang & Olufsen
remote control and must be carried out with both the
central and local system switched to stand-by!
both the main system and the BL3500 have to be in standby mode. The way to set the option depends upon the remote you have. See below:
setups (options):
positions).
then STORE.
Using a Beo 4:
pressing LIST.
OPTION?, press GO.
or 6).
both the main system and the BL3500 have to be in standby to set the option. Are you using a BL1000? if so, link + option number +store will work. For Beo4, press list and standby at the same time, press List until "Option?" is displayed, then press Go, press List twice until L.OPT is displayed, then key in the option number you want.
thanks, but unfortunely this is not the solution...
Sure, both (BS4500 and the BL3500) are in stand by mode.
I'm using a Beolink5000 and a Beolink7000, both are working fine with my "old LCS900" by pressing the Code: LINK + "option-number 0-6" + STORE
But the new BL3500 does notthing :-(
with my BL7000, to change the option I need to choose panel, setup, system, options in order to have "sound" displayed. Then I can press sound, the option number and then store. That works for me.
Sure, this is the right way. But instead of SOUND you have to press LINK to set the option on the BL3500. By pressing SOUND you change the option at youre audiomaster...
But in my case, there is NO reaction at the BL3500, even by pressing LINK or SOUND :-(
any idea????
A year is over, but the problem is not fixed :-(
Well... The BL3500 MK2 with SW 3.1 is not working. it's connected via powerlink with my (new) BS4. I can call all the menus with <menu><menu> 0X <go> but unfortunately not set the OPTION.
It is working (play music) when i call menu+menu+04+go (Display "PL SEL."), but on every following remote command the BL3500 is switching off. I thought it's maybe a problem with the OPTION. But with the "normal" way, i can't change any option. LINK+optionnumber+STORE doesn't work. Also Beo4 command POWER+LIST / LISTscrolling to OPTION / L-OPT+ optionnumner is no reaction...
PLS help me :-)
Kind regards
Michael
