I have a BS9300 connected to a BL3500 MK1 via MCL and everything works fine. I recently picked up a BL2000 with a 1612 Converter. When I connect the BL2000 to the 1612 / 9300 everything works great, but when I connect the BL3500 and switch the input to ML I get no display or sound.
I have a 1000 remote and after browsing this forum found the following:
MENU 00 PLAY shows SW 1.2
MENU 02 PLAY shows NO ML or ERROR 2
MENU 09 PLAY shows ML ON
If I do MENU 04 to switch to ML, I hear a click as it switches (I think) and then another click a few seconds later.
I figure the 1612 is working because the 2000 works fine. Before I chase down a repair for the 3500, does anyone know of compatibility issues between the MK 1 / 1.2 software and the 1612 converter? Should I chase down a 1614 instead?
(very careful about disconnecting power before making changes - and I didn't leave the MCL connected while testing the 1612)
