BL3 as center speaker
What do you think about a BL3 as center speaker?
Fine considering it’s a mono channel
What else are you pairing it with ?
If you’re in Australia even one of our second life dealers is selling a single BL17 which would also be good for this purpose.
Hi Silou,
Yes, either one or two Beolab 3s will make superb centre channel speakers, the small size, high output and acoustic lens make them an ideal choice.  For a smaller screen, a single speaker below the screen is best, for very large projection screens you can use two speakers (either side of the screen, or one above and one below if you have the main stereo speakers close by the sides of the screen).
Please drop me a line via my sponsor link below if you need any help with cabling and I will be happy to help!
Kind regards, Steve.
