BL20 / BS9000 / BV11 / Almando - static noise
I think it is a shielding problem.
As far as I know, the Almando switch has 8 pin Powerlink sockets, but they use only 4 pins - 3/5 signal L/R, pin 4 5V trigger and pin 2 GND.
https://cdn.starwebserver.se/shops/beoshop/files/multiplay-stereo-powerlink.pdf?_=1501589543
http://eu.bosscom.com/files/pdf/BOSSCOM-Powerlink-Switch-Manual.pdf
BOSSCOM switch is just the same as Almando...
I`d try Oneremote Powerlink switch.
https://shop.oneremote.dk/produkt/oneremote-powerlink-speaker-switch/
The Oneremote also switches Dataground (PIN 7) and Data (PIN 6) for Beolab displays like the BL5000.
The switch also offers galvanic isolation, and it is less expensive...
https://w3.oneremote.dk/oneremote/admin/typer/vejledninger/30017742u2uk.pdf
Stefan
Also worth trying connecting a cable from the back of the Almando box ( screw on the cover) to earth, you may try a radiator.
I’ve checked online and I don’t think your box has any screws on the back - it’s a psu for laptop type device I think.
Thanks for the tip.
Stefan
Hi Stefan
thanks for your detailed suggestion. I was not aware there are so many products available. The Oneremote looks indeed very promising and pricing is very attractive. I will wait for Almando/my dealer come up with a reply before diving into the Oneremote experience. I most probably will have to write off the 300 Euros I have paid for the Almando switch unless my dealer takes it back.
Will keep you posted.
Merry Christmas everyone!
