Hi
Former ***f member looking for some advice. I had a new pair of BL20 installed this week to replace my BL8000/BL2/BL14 2.1 combination. I did it for the looks mainly and to declutter my living room.
The situation is as follows:
- BS9000 connected to Almando Powerlink switch
- BV11 connected to Almando Powerlink switch
- BL20 connected to Almando Powerlink switch
Almando works like a charm, i.e. I can have the BS9000 and the BV11 working at the same time. Only problem is, the BS9000 produces a static noise, a buzz with some white noise. The dealer has changed the powerlink cable, situation improved, changed the mains cable, things improved further. But still, there is some buzzing and white noise. And we are out of ideas how to get rid of it.
Well almost, I have found a quick fix using the Almando app. I have reduced the volume feed from the BS9000 to the Almando switch by -6 dB and now the buzzing is gone, there is some faint white noise which is not really a problem for me. As a consequence, I have to increase the volume setting on my BS9000. Before, with the BL8000/BL2, I had the volume at 22, now I need to have it at 28-30 to have the same strength of volume.
Now my question: is that an acceptable fix for the issue, meaning do I still get the full experience soundwise? Or is there a better solution to resolve the issue?
Grateful for your advice.
Happy holidays and many thanks,
René
