BL17 + Core vs BL17 + Essence mk2 ?
Hi everybody
The BL17 can be fed via Powerlink (analog) or Toslink (digital).
In this last case, I suppose the internal DAC of the BL17 is used...
The 2 configurations I would like to compare are:
Core (Optical out) - daisychain fiber wiring - BL17 (Toslink in/out)
Essence mk2 (PL 1&2 out) - Powerlink - BL17
So my question is: do you know if there is an audible difference between the 2 setups?
i.e. is the BL17 DAC better than the Essence mk2 DAC?
Thanks ๐Ÿ™‚
Nobody ?
๐Ÿ˜ฎ
I can not specifically answer your questions, but will give you my experience with both. I have an Essence MKII connected by Power Link to a pair of Beolab 4000s. Works and sounds great. I also have a Core connected by optical to a pair of Beolab 50s, previously to Beolab 20s. Again, works and sounds great. I donโ€™t know anything about the technical differences and canโ€™t really compare the sound quality given the totally different speakers.
Thanks for your feedback anyway ๐Ÿ™‚
Did you ever connect your 20s by Powerlink to the Core?
No, I did not.
Register to access the forums, reference material, and exclusive member benefits โ€” including our monthly prize draw.
