Found a sollution, look at this, fully support by B&O and it is Somfy a really good brand.
Io homecontron
http://beointegration.com/uploaded/Velux_io_homecontrol_integration.pdf
I will be trying to get it running in afew weeks.
Chucky
Io homecontron
Chucky
Where can I find the io-homecontrol Gateway Configuration Tool 1.0.2?
Tools advanced download external driver.
you need a KLF 200, the Tahoma doesn”nt work with the gateway. Still haven”t got it working just ordered it.
OK Update
I have purchased and shifted.
Kitchen essence 2 + Essence Remote + Join Eye + Alexa on Line in
Bathroom Passive ML + Beovox 1 + Eye
Childsroom Active ML + Beolab 4
Childsroom BV 8-26 ML + Beolab 6000
Livingroom BV 7-40 ML + Beolab 9*4 + Belab 3
Masterbedroom BV6-26 ML + ML/MCL + Beovox 3000
Garage NL/ML Converter + Linkeye + Beolab 7-2
Garage Beosound Core as Audiomaster
Velux KLF 200 + Velux Skylights in some rooms working
Philips Hue working
I would really like to view first te pro's and cons of both solutions. I will not change any Beovisions in the near future the will be ML based. (I still have 1 BV6 in the garage with HDMI and the other one is also HDMI and a like a small screen in Link rooms)
Great updates @chucky!
How did you go about solving BLGW -> KLF 200 ? I just bought a KLF 200 but BLGW seems to think KLF200 is down using ethernet and tcp port 51200 closes after a few minutes.
Regards
Alex
