BL Gateway new project
Finally starting on my big project installing a beolink gateway.
I want to control
- lights, lutron gfx 3104 if still possible otherwise use Hue, but for some lights I use mirror bulbs so Lutron would be better.
- Sky lights Velux cfp electric
- blinds velux
- Beovision 7-40 Beosound 3000
- Beovision 6 x 2 and an beovision 8
- Beolink passive Beovox 1 and ml MCL converter for Beovox 3000
- 3 active kits 1636 or 2 (see below) and the ML\NL converter a lot of bl speakers all wired.
- trying to get Alexa fully integrated
- cameras as option
It will be installed in a few weeks but want to be sure infrastructure is ok. I have discovered the first flaw, 1 active kit is to old.
So I can get an active kit, use the ML/ NL converter and a delay box or the Core.
Because the kitchen is in the same room as the living I play both rooms together, not always.
I currently have only ML products but this will change this year.
I want to make sure Alexa can be played over the speakers in at least the kitchen.
Thanks for the answers on the linkroom.😁
Good luck on your fun project! You'll love what the BLGW can do.
You should be able to update your Active unit through a B&O service technician.
I think you'll find that you'll want to use a combination of both Lutron and Hue lighting. The BLGW makes it seamless to bridge all of these together.
You need to know that in order to integrate Alexa voice control, you'll have to use IFTTT and you'll have to buy an annual subscription of about $100 through Khimo. Only macros that you've created can be triggered by Alexa.
As for playing Alexa music through your B&O speakers, you'll be terribly disappointed. The quality of music from Alexa's line-out or BT is atrocious. This isn't B&O's fault. It's Amazon's fault.
I have noticed the sound quality, that is why I was looking at the playmakers as DAC. Will this not help or am I getting diappointed? I thought I just had a lousy cable😁
The active kit is so old, I think it is a hardware issue, they need to solder a chip, so not just flashing to update. A used one will than be probably be better and cheaper.
I read over the anual subscription of Khimo, it is a expensive but worth it?
Thanks!
I have a number of VELUX integral windows but never really figured out if they can be controlled from 3rd party like the BLGW.
Looking forward to hear you experience.
Good luck.
Thanks!
Since you asked, I'll not restrain myself and I'll rant a bit. Once you get the Khimo working, the IFTTT works fine. I don't see much of a lag in the responsiveness. However, I really would prefer to have a direct integration between the BLGW and Alexa. I've never felt entirely comfortable with the security of IFTTT. It's something that I would never integrate my home security system / door locks with.
Khimo argues that you also get remote access and control of your BLGW with their service. However, I've never used it.
Now I'm really going to rant: Khimo's customer support is amateurish at best. The setup process to get an account is overly cumbersome and could be simpler. The annual renewal also could be better implemented. On my last renewal, my Paypal account was TRIPLE BILLED! It took a bit of time to get that all sorted. Once you have the account or have renewed the account, you're fine....for the next 12 months.
Hmmm your a rich man if the can deduct 3 times the amount😁
Setup will be a pain as I am in the Netherlands, when I tried to activate Alexa I had to make a new Amazon adress in the USA. A refund through Pay Pal shouldn’t take so long though , it is obvious that you can only pay for one subscription or do you have multiple gateways?
Why would you need multiple gateways?
I do like the IFTTT principle, I want to try it for at least a year to see if and how it works.
After plastering my garage I put up Hue lights and a beolab 7-2 on an acive kit and setup Alexa. So cool to turn on spotfy and volume and lights on just voice😐
I cannot wait untill it is up and running
I just have one BLGW. Yes, they deducted 3x from my PayPal account. As I said, the customer support is horrible. They have no clue how to run a business.
Yup,
I now have 2 accounts at Khimo. Paid through Pay pall, only once I hope😛.
The gateway hangs and I can use the app. They will return in a few weeks for Lutron and Tahoma box for my skylights. Also my camera’s need to come in.
Now I am thinking of a touchpanel to use with my gateway.
I need the B&O look and feel, any suggestions?
I would also need a small pc, thinking of a mini mac as NAS but not shure how to integrate it yet. That is why I have hired someone for support.
I have direct control of my B&O kit using Alexa through MLGW by using domoticz, though you can use HA bridge, which mimics Hue lights, so your BLGW should be able to connect that way. Haven’t tried that route myself.
You lost me at domoticz, looked at it before, but I am not technical, I am just somebody with an extensive need for comfort😎
I cannot even get a NL/ML converter to set up as beolink active. I can wire anything but there it ends. We all have are limitations, but mine kick in a lot sooner I have noticed. That is why I need expensive boxes like the Tahoma, easy setup, plug and pray.
