BL 8000 Rubber Feet size ?
Does anybody know the size of the Rubber Feet Screw Thread and dimesnsions of the foot. I bought a pair of 8000’s from eBay but the little rubber feet are missing. There are lots of generic feet available, but I’d like to try and match them and certainly secure them well with the right screw size.
The BL8000 Service Manual unfortunately does not give the size detail
Many thanks
Bob
M5 thread
Ops! Upside down!
On my phone the images were OK...but you can get the idea.
Best regards, Dante.
Thank you so much Dante
I assume these then have a Flat Rubber Pad on the bottom of the metal cup ?
That's right.
As the rubber has gone long ago, I'm using 3M felt pads.
