Hi Leslie . I could try the batteries from the other one I have as they are clean but think I will leave well alone although it will be next week before I get the replacement . Thanks again , Richard
Hi all that replied , got the new battery fitted and all ok now , as you said it won't work without a good battery even on the charger . I can get on rebuilding a Pietra Dura picture that arrived as a pile of bits , like a jigsaw but made of marble , quite large 520 x 365 mm and has taken 2 full days and nights to piece it back together from the reverse side , now have to bond it together from the back then cut a few new pieces that i couldn't find . thanks all again . Richard
Good to hear Richard. Now, does the 2-way work as well?
Normal 0 false false false MicrosoftInternetExplorer4
Hi . Will find my BM7000 book on how to put in into two way again . Had it set a while ago to two way but my BV7 in the next room would turn off at 6,10 pm every day , it turned out to be the 7000 system doing it so set it to one way and solved the problem , no timers were set but it kicked out a signal at 6.10 every day some reason . Richard
I don't think you can put your BL7000 in one or two-way mode. It automatically "senses" your one or two-way devices when adding it in the BL7000 menu.
Hi Leslie . From what I remember from a long time ago the 7000 master has to be set in option 1 or for 2 way option 2 , but was a long time ago and can't find in the books but will have another look .
Richard
Hi . Can't find option programming in my book , but , played a cd and track number comes up and updates when I track advanced on the masted but no volume at the top . Got my other bl7000 thats with a BM4500 and that shows track and volume at the top , strangely so did the battery changed one but no volume when the other BL7000 was removed . As track in showing I presume 2 way is on but it's not displaying the volume . Have it on a floor stand and looks good with the other one on the table , stereo BLink7000's must be a first .
Richard
You're right, thought you were talking about the remote...
