Normal 0 false false false MicrosoftInternetExplorer4
Hi All . I
have a beolink 7000 remote that has a problem , off the charger it’s dead but
when placed back it shows ‘Stand-by’ ( blue screen on and a few of the red
options below ) it then briefly goes to the red dot top right corner as it
should but then lights up again as before and continues to cycle like that
every 15 seconds or so . Have switched
of the 7000 master but no difference , is there a master re-set somewhere or is
it the dead battery causing the problem ?
Richard
