BL 3500 trouble
Hi
I just installed a Bl 3500 in my bathroom and linked it to my main room. I am having some trouble with the setup though. Is it posible to listen to a CD in main room while listening to TV audio on BL3500?. If i press TV in my bathroom, the mainroom switches to TV AND mainroom speakers are on?
THEN if i press CD in my bathroom, i can listen to CD while the mainroom continues Previewing Tv...
BS 3000 in mainroom, option 0
BV 7-32 in mainroom, option 2
BL 3500 bathroom, option 6
I might be out of line here, but is not this only possible if you have the CD in a BC2, which is capable to distribute parallell active sources to linked speakers in linked rooms....
Just my 50cents. Sorry if I'm right  🙁
/cjocc
That i dont know, but anyway. IF everything is turned off, turning on your linkspeaker on TV should not turn your main system and main speakers on , should it??
