Oh, I actually was not aware. But the other commands work?
BGAdaptor - Control a Data Link source with Connected Audio
Yes, other navigation commands are as expected.
[2026-11-27 10:02:01] {"state":"Standby","track":"-","deck":"cd","title":"CD 3300","product_name":"","playing":false,"driven_by":"","driven_by_ip":""}
[2026-11-27 10:03:10] {"state":"Playing","track":"-","deck":"cd","title":"CD 3300","product_name":"","playing":true,"driven_by":"","driven_by_ip":""}
I note the user manual for Beomaster 3300 has a remote that doesn't have numerical keys, so perhaps no surprise that datalink doesn't support track number.
I have a Beogram 4500 connected to my Beosound 9000, but as you'll probably know, the Beosound 9000 Aux socket does not support datalink, so the turntable can't be controlled by remote. Would this clever device allow me to remote control my Beogram 4500?
I also have a Beovison 11 TV and a Beosound Moment; both NL products so both are connected to my Beosound 9000 via a Beolink Converter - I mention these in case there's any way of connecting via these devices instead?
I really would like to be able to control my Beogram 4500 via remote, and am hoping this might be the solution! I have a Beoremote 1 IR, Beo6, and several older remotes.
Ah yeah, that could be a clue :)
Should I make a build that allows you to hide the track number, or do you not care?
Hi CharlieWednesday,
It won't help with your BS9000 (although that would be nice too), but the core funtionality should be able to work with Moment (I have not tested with Moment, but since it's ASE-like it should work, and if it doesn't, we can MAKE it work, I'm sure).
This would turn on the record player when you select line-in on moment and turn it off when you select a different source or press standby. I don't think we can get next and previous to work though, but IMO, on record players, it's most important just to be able to start and stop. (Next and previous commands will still be possible via the web page)
