Beta for Mozart platform products available
Hiort wrote:
FYI
Tried the following:
Play TV source on Beovision 11 and using B&O app to expand sound to Emerge.  NOT WORKING
Using B&O app to select TuneIn channel to play on Emerge. NOT WORKING
Using B&O app to select Deezer song to play on Emerge. WORKING
Play on any NL device and using app to expand play to Emerge. WORKING
Play B&O radio on Emerge and using app to expand to a NL device. WORKING
Expanding BV11 sound to Emerge should work.
It would be really helpful if you can submit this feedback via the app or send me the serial number of your Emerge in a PM then I will analyze the device logs so we can get this fixed.
Thanks for participating and helping out. It is much appreciated.
Hiort wrote:
FYI
Emerge have B&O radio not Tuneln
Livingroom: BL3, BL11, BV11-46 Kitchen : Beosound 1 GVA, Beocom 2 Bathroom : M3 Homeoffice: M3, Beocom 2 Library : Beosound Emerge, Beocom 6000 Bedroom : M5, Essence remote Travel : Beoplay E8 2.0, Beoplay P2, Beoplay Earset
c-larsen wrote:
All of these use cases should work.
But Emerge has only B&O radio not Tuneln!?
Sorry, you are right. I read it as expanding TuneIn playback from another device to the Emerge. That should work. Only B&O radio is supported as local source on Emerge. Edited my response.
PM sent
Understood. I will change in summary above.
Happy with this feature. Makes it possible to select station on B&O radio (which isn't available on TuneIn) and expand it to BS1 (mk2 GVA) and Essence MK2 simultaneously.
No Deezer app needed anymore is also nice.
Wow, that's a really new cool feature! That would mean you could add emerge or balnace speakers to your TV! Would this work on Eclipse as well? But it would just be expanding the sound source , it will not be a seperate speaker in the eclipse to use as surround?
Decided to test out my Balance, and I’ve got the beta software, updated my B&O app too but weirdly I cannot find an Enable BeoLink toggle for Balance, nor am I able to find a multiroom list.
No the Eclipse wont see it as a speaker to use in a speaker group, like it does with Beolabs.
