best speakerfabric/cloth to match Bang & Olufsen quality
Hi all,
Have somebody over here ever tested some resource for speaker fabric. A website to order it would be great. I'm very critical when it comes to quality, so only reply if you're sure that it matches the original as closely as possible.
Thanks for helping me out.
Michel
I actually found a perfect match to my S45 (70s) fret material using 28 count black linen that is used for cross stitch. It's a perfect match to my eye. Standard speaker fabric is too thin and lacks the body of the linen. I have not found a match for my C & CX speakers yet.
B&O original speaker fabric/cloth quality? Are you serious? One sneeze and you have a hole in your cloth!
The looks are great though!
michgal wrote:
Hi all,
Michel
What type of speaker you wanna recloth Michel?
Not sure what you mean. The fabric I've seen always seemed sturdy and thicker than the usual fabric on many other brand speakers. Now the fabric on the 80s S45 was much more flimsy.
I was more talking about the fabrics like Penta's, RL series, Beolab 6000's, very thin...
I'm sure many companies such as romo may be able to recommend as they are in the fabric business. I'm a bit of a fabric fan. What I think would look great is the fabric that Mercedes use as the fabric for the sun blind under the panoramic roofs.
Yes - but remember that many Penta's and RL's are 20+ years now - so no wonder if the fabric is not at it's best anymore...😕
Like the Beolab 6000's 👍? I'm talking about fragility of the fabric used. Beauty has to suffer....
Michel - try
