Beoxox RL 35
Just purchased a pair of these on eBay.  One of the speakers has something rattling around inside.  Can't figure out how to get them apart.  Only screws are the 2 plastic ones that hold the straps and the t small screws that hold the speaker wire spring clip block.
Anybody?
Beovox, not Beoxox
Remove the straps.
Then carefully prise off the front cloth frame.
It's held in place by a handful of 5cm long pieces of double-sided tape.
Then dismount the woofer to get inside.
You'll probably find a lose ferrite core from one of the filter coils.
Thank you.  Is that repairable?
If a coil is loose and wires undamaged, just glue it back where it was before. Use silicone and clean with IPA before gluing
Retired
Printing machine technician
Rock and Roll music
Collecting Vinyl
