Beoworld app
Hi Cleve,
I developed the app for Beoworld.
The app remembers your login details as a convenience, but if you want to log out, just type in some incorrect login details.
There is no way currently to edit a post. For this you have to use the normal website. This app was developed using reverse engineering techniques, and I wasn't figure this feature out.
p.
These forum, as well as the French forum are missing in the app as they are not on this page. http://archivedforum2.beoworld.org/forums/default.aspx
p.
Hi Phil,
Thanks for this great app!! A suggestion for a future update: when I read a post in a thread, I have to go back to the thread to select the next post, read it, go back, etc. Adding up and down buttons in a post for jumping directly to the next or previous post would enhance reading posts enormously for me!
Regards,
Bart
Hi Phil
Thank you very much for this update. French forum and more are now easy to access. That's a great job !
Nicolas
