Beoworld app
I have been using the Beoworld app on my iPod Touch. It is really good and makes accessing the forum really quick but have two concerns.
Firstly, there seems to be no way to log off.
Second, how can I edit my posts once they have been posted - I can't correct spelling mistakes, for example?
Any advice gratefully received.
Cleve
Hi Cleve,
I developed the app for Beoworld.
The app remembers your login details as a convenience, but if you want to log out, just type in some incorrect login details.
There is no way currently to edit a post. For this you have to use the normal website. This app was developed using reverse engineering techniques, and I wasn't figure this feature out.
p.
Thanks Phil,
It is still a really good way of accessing the forum -I will just have to be more careful with my keying!
Cleve
Hi Phil!
Thank you for developing the App. Great work!
One question to ask:
Where can I find the BeoSound 5/ BeoMaster Forum (or is it just me who can't find it)
Greetings
Michael
These forum, as well as the French forum are missing in the app as they are not on this page. http://archivedforum2.beoworld.org/forums/default.aspx
p.
Good news... by chance this morning I found out that on the Forum page mentioned above, if you click on Start a New Thread, it shows the full list of forums. I thought I could use this to obtain the full list and display it in the app.
I have done the change in the app and I am currently uploading it to Apple. It will take about a week before it is validated.
As the Start a New Thread button only shows up if you're logged in, so will the full list. When not logged in, the shorter list will be displayed.
p.
The new version is online now...
Hi Phil,
Thanks for this great app!! A suggestion for a future update: when I read a post in a thread, I have to go back to the thread to select the next post, read it, go back, etc. Adding up and down buttons in a post for jumping directly to the next or previous post would enhance reading posts enormously for me!
Regards,
Bart
Hi Phil
Thank you very much for this update. French forum and more are now easy to access. That's a great job !
Nicolas
Excellent thanks Phil
