Somewhere on the forum there is some drawings with measurements, but
without the "nose", on Ebay I saw a pic of presumed S 45 stands with a
(smaller) "nose". As I'm waiting (and bored) for a pair of S45s I
started to think about it, Speaker footprint is 265 Mm wide, 200 Mm
deep, size of foot found on forum is 265 x 255, if I put the crossbar
directly on the upright, the S45 will hang about 50 Mm behind the front
of the stand, and thats bad design, the nose is with crossbar 30 Mm,
this distance computed with the newest cientific knowledge (one eye
closed and my thump) this will bring the bottom edge of the speaker to
the front of the stand when pointed a little upward. My stand has the
footprint 265 x 250 Mm, So if you make your own stand, wide= speaker
wide, deep= speaker deep + 20 Mm and crossbar directly on upright, or
"nose" and deep= speaker + 20 +nose. If the speaker weights more than 12
Kg I recommend 3/4" x 1.1/4" 18 gauge steel. I have welded the upright
to the foot, it should be attached by a M6 screw, but its difficault to
make without a lot of work.
Homedepot has felt or plastic pads to glue under the stands.
The brass bushers: Hole on crossbar is 10 Mm crossbar 5 Mm thick,
busher is 8 x 7 Mm where it through hole attach to speaker and 15 D x 9
with sinkhole for M5 Allen screw behind crossbar. this should give
enough play for inclination ajustment. Ajustment screw is M5 allen, head
pressed into brass, I did these brass details just because I could.
Login to view image
Login to view image
Login to view image
