Greetings to all gentlemen.
Is my first post here,.and i have a question about an issue.
My small son throw to the floor the ferritcore and it broke to many small pieces.The pieces went to the trash.
So is this fine while playing?.Perhaps there will be a problem? What should i do?
Very difficult to find a crossover donor.
Another question to the experts here.Is it possible to replace this 6700001 ferrite core with 6708007?
What will be the reaction?
Also i want to ask if it's wise to replace the bass ferrite coils,.with these:https://www.ebay.com/itm/1-Audio-Tschentscher-Luftspule-0-70-mH-1-50-mm-Draht/111219433322?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
Thank you in advance.
link
link
link
link
