BEOVOX S45 CABINET BRACING?
QUICK QUESTION ABOUT S45 CABINETS
I am about to refurb my S45's with new: crossover caps/resistors, internal wiring, and cabinet cleaning up
Now while I am at it I was going to stiffen the cabinet, but before I commit to something of this sort, does anyone know if the cabinets follow the BBC LS3/5a thin walled construction? if so, then bracing the cabinet would be a terrible thing for the sound
Why? I have both S45.2s and LS3/5As and both are great speakers. If they had needed more bracing, B&O would have done it. The S45.2 sounds better than it has any right to. A good recap and refurbish should be fine. Don't gild the lily.
Your answer is as I anticipated.
That said the crossover board is a tad messy
