Hi all,
Long time lurker, first time poster! I've only recently joined up as I've wanted to ask a few questions. I have a pair of Beovox S45-2 that were bought for my birthday 2 weeks back. I've seen a fantastic post about sanding and oiling them in the archives so I've got all the bits and bobs together to sort that out. One of the woofers also had the magnet slip issue that I resolved thanks again to the forum. They sound magnificent but I think they would benefit from being recapped. I am in a bit of a jam as whenever I search online there are a plethora of Capacitors that is just confusing to me! I have fairly decent soldering skills and am a capable DIYer with the right instruction. Can anyone direct me to suitable replacements?
Also, I have just bought a Beomaster 1000 from eBay. The outer case is MINT! I bought it as I had my suspicions it had never been touched... and I appear to be right! It has more dust than the Sahara Dessert inside and has the little schematic inside which never been opened (until now!). It "works" but has a few issues. FM radio is lovely and loud but sometimes the sound fades away. When you turn it off or depress/wiggle the FM key a few times the volume returns. I also have a Beogram 1700 with an MMC-20EN cartridge fitted which is really quite quiet when I hook it up to the QII connection. I have the speakers connected up to the right inputs and I have the record player hooked up to the right input before I'm asked to check :)
The speakers and turn table work perfectly well with a modern amp. I have bought some contact cleaner to try to see if this makes any difference to the Beomaster, but yet to use.
In summary, I'd like to know what capacitors to get for my speakers and what can I do to improve my Beomaster? I know some of the caps need replacing. Which ones are most important? I'm not looking to do a complete rebuild but just replacing the important bits. Does anything else need looking at?
I know I'm probably asking the (Beo)world, but if you don't ask... you don't get. Right?
