Beovox cona
Hello
I'm looking for a beovox cona, and it is, of course, used.
I was wondering what i should be looking for when buying it?
I have the cx100 and I know that the membrane will break with time and I was wondering if there is a similar weakness with the Cona?
I think the cons has rubber membrane. At least there was no issue with the one I had before.
Is it easy to check though?
Just look under it.
Use a flashlight (app). That might help. On the Beoworld product pages you see a shot of the bottom as well. Not easy to check the condition of the membrane visually.
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096 Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55 Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL) Bedroom: Sony KD-65XH9077, Beosound Essence MK II with Beolab 6002 and Beolab 11 (all white, wall-mounted) Dart Room: BeoPlay V1-40 on floor stand Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
Okay, I will have to open it then?
Can I here if it's broken?
From what I can tell, the loudspeaker driver is quite clearly visible under the grille at the bottom (see an
Human interface designer at Bang & Olufsen.
