Beovox C75 replacement driver
Howdy,
I recently bought a pair of Beovox C75 speakers and the top woofer on one of the speakers is crackling as it plays. The surrounds are fine, look to be recently replaced, and i've had the speaker playing free from the speaker box confirming it is an issue with the driver, and not loose components.
Assuming i do have to replace the driver, is it possible to source an original unit, or will i have to replace both drivers. And if so, what can i use as an adequate replacement?
Thanks, Jake
Here:
I saw this but i have absolutely no idea how to purchase from this website.
Use the contact form.
