Beovox 5000 Panel
Good afternoon,
I found a pair of Beovoxes 5000 Panel recently with burned (cone) bass woofers I am interested in. Still high priced, however there might be some margin when negotiating. Just wondering, if the bass woofers could be repaired when burned, as I saw an add, when buying some refoaming rings also for the cones or is the damage so big in this case, that only replacement would work? If so, what bass woofers have been used and are they still available`?
Thanks in advance for any advise.
Tw
I think that the best solution would be a replacement. I'm not quite sure if these can be repaired although members Dillen or Keith are experts on this field.
Maybe you should contact them directly.
There is a company in the Netherlands that can replace burned coils of speakerunits, www.speakerreparatie.nl . The site is only in Dutch.....
