BeoVox 2, mounting depth
Dear forumers, who knows, what is mounting depth for new BeoVox 2-1 (smallest). On the leaflet it's indicated as 10,5 cm for both bigger and smaller BeoVox, but InWall Cabinet 6029 only 8,6 cm thick (together with MDF plate). How possible to accomodate 10,5 cm inside of 8,6 cm box? I didn't find any picture of BeoVox from back. Is sombody can do? I thinking about to mount BeoVox 2-1 in light partition wall with depth only 8,8 cm. Is it possible?
A Very Warm Welcome to Beoworld.
Perhaps the attached document will assist you...
Thanks a lot. I expected something like this but did't find manual for InWall Cabinet. Well, it means I can order BeoVox 2-1 for my walls.
