Hi there;
hope you are all well.
Just wondering, in regards to a BeoVox 1 setup, i'm thinking of installing outside. If i connect using the powerlink socket on my BS9000, will i be able to skip, pause, change cd etc etc from the remote outside, or will i only be able to control volume and whether the sound is on and off. I'm a bit confused as to how all the connections happen. Also what is the external amplification box with the BeoVox 1 for?
