Beovision7 mk 3 set up Apple TV help
Hi there!!
I have recently aquired a beovision7 type 9334 and I’m trying to set up my mk3 Apple TV on it.
I plugged in the Apple TV through a video converter which has hdmi from the Apple TV going in and then dvi coming out. Also coming out was a headphone to rca audio cable.
 Initially when on the DTV mode as selected on my beo4 remote, I got the image from the Apple TV but no sound. I tried setting up the sound and now I don’t have vision or sound.
Im struggling to set it all up via my beo4 remote in the menu- options- connections panel while on TV mode
im not sure whether I’ve connect the audio rca into the right sockets on the back of the beovision7.
 This is a link to the converter I have
If it`s a BV7-32 mk3 and if connections are similiar to BC6-26 and if I remember correctly, then try AV3 with stereo rca inputs and assign the DVI socket to AV3
Welcome to Beoworld.
Stefan
Hi there Thanks very much for the reply. I still have no luck getting picture or sound from the Apple TV. Initially I did get a picture but I must have messed with the settings. When in connections, what exactly should each of the AVs 1-4 have as their 1 source 2 audio socket 3 Ir socket 4 hdtv I’m quite confused sorry
