I wonder if it's possible to get gapless audio playback on the bv11 by connecting an external USB harddrive Directly.
Regards,
Musicman
Regards,
Musicman
Does cover art show?
Can it create playlists?
Can it be used as s basic music player?
1: yes, if your files are tagged properly.
2: no!
3: yes - very basic, if you are willing to do pretty much scrolling.
I would recomment, that you use a DLNA server, where you have your content (instead of a connected usb-drive) and a DLNA controller app (like PlugPlayer, 8Player, Bubble-UPnP etc to choose, what you want to play - and send it to the BV11.
But using it with a DLNA server is not going to playback gaplessly is it? When I'm streaming music from my beosound5/beomaster5 it curtainly does not!
That is why I'm wondering if it would do that with a USB harddrive directly connected to the beovision11.
I did not answer to that question, since I have no experience/knowledge of playing back from a connected USB-drive.
The BS5 plays gaplessly back from the BM5 without issues, because it basicly is a pc-based setup.
Using the DLNA server for playback on the BV11 does not provide gapless play.
Gapless playback is a 'problem child'' for any DLNA-based system, and requires some tweaking on the renderer site.
