Beovision11+ Bose lifestyle 18
I just bought a Beovision 11 46 "TV, which I would like to have connected with my Bose Lifestyle system. The problem is that the Bose is of "older" date and therefore does not have HDMI output. Previously, I had my TV connected with a component cable. My question is how I easiest and best connect my Beovision and Bose systems?. I here found that it is possible to buy an adapter so that you have the component cable at one end and HDMI in the opposite - a converter. the solution works not optimal and the inverter is relatively expensive to buy.
I hope that there are some of you who have experience or ideas on how I can connect my Beovision and Bose systems.
Congrats on the bv11-46, to be honest the sound from the TV speakers would be of a higher quality than the Bose system, which are not regarded for producing great sound.
As you have a centrepiece to the world of b&o, I would forget about the Bose and buy some beolab speakers to compliment the TV, and expand as funds permit.
Basically I agree with butch1, but if you really want to....
There is no way to get a digital sound signal out of the BV11 (apart from using WiSA).
You would have to use the PowerLink output's - configure these as what you need and as 'Line'.
From the User Guide:
'Important!
if you select LINE in the SPEAKER TYPE list, the volume will be very loud and you cannot adjust volume with your Beo4/ Beo6 remote control. You must use the product’s own remote control. LINE is used for, for example, non-Bang & Olufsen amplifiers.'
