BeoVision Televisions - Technical Sound Guide - updated version available
An updated version of the Technical Sound Guide is now available at the B&O support pages.
If you select your tv and go to the buttom of the support page, you will find the updated version (also covering Harmony and Eclipse).
This is the link:
https://bangolufsenassistentgohe.blob.core.windows.net/manuals/TELEVISIONS/TECHNICAL_SOUND_GUIDE/technical_sound_guide_televisions_2004.pdf
Thanks to Geoff Martin for the update 😁
Best regards Dyssegaard
Thanks a lot!
Jean
PS Make the link clickable. There are two "chain" icons in the posting menu
Finally!
Clickable link:
Thanks all, a great read as a refresher!
Will definitely play around with my settings tomorrow!
Excellent, some more suggestions for speaker positions on page 18. Great update from Geoff!
The bass management table is gone.
On page 9, section 3.2.6 of the Technical Sound Guide (TSG), it is stated, that you should be able to select a Listening Style of ACTIVE or PASSIVE for the different Sound Modes in your Beovision.
I’m not able to do this on my Eclipse 1st. Gen.
On my BV11 it is available as discribed in TSG.
Do I need new glasses or am I not the only one who cannot find this feature on the Eclipse? 😮
Edit: TSG was updated May 10, 2021:
https://assets.ctfassets.net/8cd2csgvqd3m/7phXBVRH0W44n7Bx3Ej3vf/c4a1b01499bbaea76fc9ac31c074197f/Technical-Sound-Guide-2105.pdf
A correction regarding Listening Style was added šŸ˜•.
