BeoVision MX4002 stand.
Did B&O really made a Stand for the MX4002 TV??? I am having trouble with this stand, my MX4002 sits very bent on this stand. The stand came with 4 screws, but I don't know what they are for?????
These are the pics of the stand I bought from ''Iconic AV''.
link
link
Hi shane2468
Im not sure if this is the right stand looks more like a stand for mx2000
dont know its the same the four srews are to be mounted in the bottom of
your mx 4200 there are two metalsrews and two that are for plastic.Turn you mx
4200 upside down fit the stand on the bottom and mount the srews if it do not fit
i think its the wrong one
kind regards
jan
My TV is a MX4002, not a 4200.
4200, 4000, 4002, 3500, it makes no difference they are all the same!!!!!
There is nothing wrong with the stand! It is the one for the job. The 4 screws are provided to hold the TV to the stand.
Having said that, you probably have the same 4 screws still in the bottom of your TV.
Cant help you much more from here as I dont have one I can photograph at present. Easier to work out if you turn the TV on it's side.
The wire coathanger thingy will get in the way, you can remove it but the stand will go on without doing that. It is not rocket science!!!
HI
Sorry about the mistake but it.s the right stand then mount it as I described before
good luck
Regards
jan
Thanks very much to both, joeyboygolf and birgerbum. I have managed to get the stand onto my MX4002, the combo looks nice!!!!
But I had to remove the coathanger, it's no problem to me. I don't need the coathanger anymore, if someone needs it please let me know. I don't know how much these things sell for??? I also have the 4 screws for it. But the 2 small metal things are bent though. They were supposed to hold the hanger down when screwing down the screws.
Thanks very much
Shane
Now you have the TV mounted you can put the coathanger back on for completeness!
TV stand is going very well. Here are some pics to show. Sorry about my HiFi pic, that's to show I'm not much of a B&O nerd.
link
link
Wow that sure is an ugly stereo you got there!! 😂 Though it probably sounds better than mine >
The MX looks quite nice in your space though, can't believe you still play a Dreamcast - i haven't seen one of those since i started high school!
Hi shane,
just caught this thread, glad you got it so quick, i sent assembled as requested so you didnt have to put it together , i had sent you a picture of where to put the 4 screws in, but it looks like youve sorted it now anyway.
Enjoy 🙂
