Beovision Horizon/14 Quick-Start menu
does anyone know how to access the Quick-start menu for the Android based TV's?
This is stops the TV from displaying the B&O logo at start up.
C
It does more than that.  It keeps the TV in a sort of hot-standby where it's almost on but the screen is off.  Very useful for trimming about 1 minute off the start time of my Beovision 11.
I just wanted to confirm: Your BV11 takes over a minute to start up? That seems like an awfully long time. Even my BV11 from cold start (B&O Logo upon startup), takes less than 25 seconds to start up and open the electronic curtains. Likely even quicker actually.
The menus are different on the Horizon. I have no idea how to access it. The TV just got installed today and I was shown the menu but I couldn't find out how to get back to it once he left. Do you guys know?
As far as I know quick start settings (two adjustable time frame periods) are possible on the non android smart tv's (BV11/BS4/Avant/V1). My V1 opens very quickly without logo. The Android TV's don't have this quick start setting hence I can't find it anywhere in the setup menus of my Horizon.
It does have a menu for this  I can confirm. I saw it with my own eyes today! I just forgot to ask how to get to it.  I've just contacted the dealer and hopefully I should get an answer for you all :)
interesting!
It does when starting it from the Moment.
There you go! Beoworld beat the dealer to it!
Apologies for the double post.
Is is there some form of button combo you need to do to apply the settings. Whilst I was in there I adjusted the automotive picture sensitivity lower so the screen doesn't go as dark. The quick start settings and the room adaption settings haven't made a difference since I left the menu?
