Beovision Horizon Update 3/11/2017 Released
The new version is QM153E.0.6.3.9. For Android TV’s.
The process took 1.5 hours.
As yet I have no details on the performance improvements or fixes...
Beoaus
Very curious to know if this release will make it App compatible!
Karel.
Well I have Deezer (Deezer for Android TV ) installed and running plus Stan, YouTube and Google Cast so I am ok. The standard Netflix app installs but will not run so I uninstalled it which is not a problem for me as we don’t use Netflix.
The TV response has improved when switching channels, Freeview, etc.
I am sure someone will have full details of the Android update and other elements of the upgrade available soon.
Beoaus.
Below is the list of additional features (App Control) and SW fixes. Enjoy!
Software version 0.6.3.9
New features
- Support of the Bang & Olufsen app (app version must be 1.3.0.10740 or higher).
Symptom
- No/wrong audio, incorrect channels, playing e.g. TuneIn/Moment (no center sound)
- Sound missing when TV is switched turned on
KE16784
KE16504
- TV crashes and re-boots
KE16004
- Sound stopping on TV when joined via Multiroom in a Atlona Matrix setup
- The sound drops for 5 sec. when selecting TV after having been playing audio
KE16529
KE16712
TV switches on when another product borrows source
KE16325
MHEG teletext not working in UK after upgrade 0.5.0.96->0.5.2.4
KE16506
BLGW app always present in TV list
KE16301
Motorised Wall Bracket/Floor Stand not turning completely back to wall at standby when returning from maximum outer position
KE16497
Changing channel fast – LED switches on and off randomly
KE16108
FTS language changed for Japanese and Korean
KE15946
Horizon 40 appears offline in BeoTool
KE 16551
Sometimes we get a half green screen when using an Altona UHD Matrix and it is displaying UHD content from Kaleidescape
KE16317
TV will not start up from a Beolink Gateway when TV is connected via Wi-Fi
KE16770
TV pop-up "Unfortunately, BtB_Project_1_0 has stopped"
KE16452
TV pop-up "Unfortunately, UPNP has stopped" with SW 0.3.0.x
KE15800
When playing a Link source, the TV screen does not stay off. After 10 minutes the screen starts showing metadata and does not switch off/picture mute.
KE16768
Wrong name when installing PUC file for DirecTV Generic-DVR
KE16035
When using LINE input L/R, the TV will switch off by itself after some time
KE14905
Finally & great! complete multiroom feature. Downloaded and connected with app. Not 100% flawless but maybe reset complete network will do the trick. Will try later tonight
I guess this sw is for the AvantNG and the BV14 too?
Or?
Or?
Just updated my BV14... controle though iPhone & iPad is possible *happy*
Will do further testing this weekend.
Karel.
The Avant NG and Horizon have both the same FW version. Coincidence ?
Engineering since ever...
The Avant NG is an Android based TV as well. So here, I believe the same upgrade is applicable.
Beoaus.
With B&O, I learned to never believe anything :-)
