Beovision Horizon 40
Hello
The remote of my horizon or the horizon lost somehow the connection to the remote ??????
Is there any way to make them talk to each other again ? Other than marriage counseling??
Regards
Yes. Please unplug your TV power for a few minutes then plug it again.
you will notice a solid green light on the upper right when you plug back the TV power. That is the time to pair your TV
go to your remote and look for pair then select open pairing.
Try that I hope it helps
Thanks working again
